Heating Dyes
Now that has me all wound up! Can't wait I hope it is sooner than soon! I will be watching for it. Thanks all
HEAT in your anodizing tank will be a thing of the past - watch for new anodizing instuctions - coming soon.
Heating Dyes
Can you use the ceramic heaters to heat anodizing dyes or do you have to stick with glass or teflon heaters? Thanks Also has anyone used the coolworksinc. Iceprobe chiller in a anodizing tank. Not sure what the probe is made. This my be something Caswell may want to check into. If they can be used it would be a less expensive way to take some heat out of a small setup. Compared to a heater chiller. Thank and happy plating!Tags: None
