I've encountered a problem in my first anodizing trials. The dyed parts are covered with pinholes where the bare aluminum shows through. Has anyome encountered this as well?
I am preping by degreasing with Simple Green and etching in a sodium hydroxide solution. The electrolyte is 16.5% sulfuric acid, powered by a 6 amp / 12 volt battery charger with a 6061 aluminum cathode. The dyes are Rit clothing dye. All water used for rinsing and solutions is deionized filtered water (maybe not as pure as distilled, but cleaner than tap water).
captmorgan
captmorgan
