I just got a new 30V, 5A max PS, CC/CV and was trying it out. My test piece was about 4 in^2, and I was trying for between 6-8 A/ft^2, so I was only using 0.2 A.
I watched my voltage rise steadily from about 13V to 30V in the course of an hour, so I knew something was off. I suspected a poor electrical connection, but I let it go...
Attached are a couple of pictures. The first is the piece directly after I removed it from the anodizing tank. Notice the dark gray color of the wire. I believe this is the beginning of a hardcoat.
I think that after a couple of minutes, the electrical connection between the wire and the workpiece was almost completely lost, and the wire was seeing the full current, hence a MUCH higher current density than calculated.
I dipped it in the dye tank, and confirmed my suspicions that the part was poorly anodized, likely due to a faulty connection. However, it appears that the wire did absorb some dye. I thought that a true Type III hardcoat would not absorb dye. Is this correct?
Just thought I'd share my experience with you guys. Enjoy!
Edit: My FTPs not working ATM. I'll get the pics up when I get a chance.
