anodizing tank at 264 g/l
  • anodizing tank at 264 g/l
    anodizing tank at 264 g/l and slow need to get back to 180 -200 or should i just leave it to come down by its self ? please help
    is this what is slowing me down ? to strong ?
      Dissolved Aluminum in the Bath
      Jason Vanderbroek
      315 946 1213 x116
      www.caswellplating.com
        No freeH2s04 type 2
          I would remove about 20% of the bath and replace it with DI water. 264g/L is a pretty high H2SO4 level and will make it tough to do good consistent work.
          Process control doesn't give you good quality, it gives you consistent quality.
          Good quality comes from consistently doing the right things.
          Process control systems for Anodizers
          If a post helps you out LIKE the post
          I'm not an Amateur Metal Finisher. I've just been around the industry for a dozen years or so helping and consulting when and where I can.
            Thank you, I will do this
              8.7 total alm
