Ti Rack and 720 rule
  • Ti Rack and 720 rule
    Hi, I just bought a titanium rack. Just to be sure. Do I need to add its area to the aluminium parts when calculating with the 720 rule?
    Any advice will be welcomed, thanks.
    Luis
    No you do not. Titanium will stop pulling appreciable current after 30-40 seconds in the bath at a given voltage.
    Process control doesn't give you good quality, it gives you consistent quality.
    Good quality comes from consistently doing the right things.
    Process control systems for Anodizers
    If a post helps you out LIKE the post
    I'm not an Amateur Metal Finisher. I've just been around the industry for a dozen years or so helping and consulting when and where I can.
