Amp fluctuation
  • Amp fluctuation
    Hi! Sometimes my rectifier fluctuates by .1 amps, I made sure I had good connection all around with a multimeter. Nonetheless it doesn't maintain constant amps. Any ideas/suggestions??
    Thanks!!
    Which Rectifier do you have ?
    Does it drop off only while in session or while it is out of the solution as well ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Thanks, I have the HCS-3600 / 3602 / 3604 (30 Amp)...HavenĀ“t tested out of solution, just under session.
        What voltage and current is it running at when this happens?
        What are your process conditions (bath temperature, agitation level, process area)?
        Process control doesn't give you good quality, it gives you consistent quality.
        Good quality comes from consistently doing the right things.
        Process control systems for Anodizers
        If a post helps you out LIKE the post
        I'm not an Amateur Metal Finisher. I've just been around the industry for a dozen years or so helping and consulting when and where I can.
