Black dye has green tint
  • Black dye has green tint
    Has anyone had experience with caswell black dye turning green?
    I am new to anodizing.
    We use the 720 rule when anodizing following CC.,
    dye PH 6.4 temp 140F dye time 15 min.
    sq ft 0.53
    amps 7
    volts are 4.3
    time in solution 42 minutes
    12% acid solution
    tank temp 71F
    Sealant is 5.8 ph 200F 20 minutes. Nickel Acetate
    I think it could be the dye? My gold S, violet DS did not have green tint after sealing.
    I dumped my dye, rinsed bucket and am refiling now. However, i ordered several pints of black dye at the same time. So really, i just dumped one and am most likely filling my dye bath back with a black dye mixed from the same batch by Caswell.
    Does anyone suggest a different dye supplier?
    Is the Dye in the bath container turning Green ? or Spots of Green on the piece once dyed ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Jason,
      The dye in container is very black. I tried to upload a photo but it says the file size is too big. If you give me your email address i'll send the photo to you directly.
      It's certain areas that are almost a translucent color of green.
        jason@caswellplating.com
        Jason Vanderbroek
        315 946 1213 x116
