Volts are peaking
  • Volts are peaking
    I've been having troubles with my voltage through CC method.
    My surface area is correct
    Following strict to 720 rule
    When I fire up rectifier volts are reading 10 when no current has been applied yet.
    25-35 minutes in to my plating the rectifier peaks.
    I am using aluminum weld wire to rack my part. The wire is getting burnt for sure.
    What do I do?
    What rectifier are you using ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      I am using a Volteq 0-30V 0-200 Amp DC voltage rectifier.
      I have been using aluminum weld wire to rack my parts. The wire has been getting burnt and I think that's where current is meeting too much resistance. I ordered some anodizing rack components from Sequel Corp. Hopefully that will remedy my situation.
