The most important tank in anodizing
  • The most important tank in anodizing
    My friend Tim over at Finishing & Coating (.com) just published one of my papers regarding the most important tank in anodizing. I think it can benefit at least a few people here especially those just starting out.
    https://www.finishingandcoating.com/...anodizing-tank
    Enjoy
    Kevin
    Process control doesn't give you good quality, it gives you consistent quality.
    Good quality comes from consistently doing the right things.
    Process control systems for Anodizers
    If a post helps you out LIKE the post
    I'm not an Amateur Metal Finisher. I've just been around the industry for a dozen years or so helping and consulting when and where I can.
    Thanks for the link Kevin, Looks good....I think the take-away from this is diligence and cleanliness. Both very import across the entire system in order to achieve a consistent, quality repeatable outcome.
