Heating ??
  • Heating ??
    Hi, I was called late last week by a buddy that owns a machine shop, He purchased the 20 gallon system and has called on me to get it set up. We got some racks made and are putting together a list of equipment we will need. My main concern (for now) is what we should order for heaters. What do you recommend for this 20 gallon system? do you recommend keeping the tanks at temperature even when not in use? If not, it seams like it would take a pretty large (wattage) heater to bring the tanks up to temp in a fairly quick amount of time (less than an hour) Any help or advice would be greatly appreciated, before last week this wasn't even something I had considered doing so i've been reading everything I can.
    Thanks
    Chad
    https://www.industrialelectricheating.com/ Has submersible heaters available.
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
      Thank you Jason, I saw those and wasn't sure they would be enough with the larger tanks.
