Anyone do Type III hardcoat anodizing?
  • Anyone do Type III hardcoat anodizing?
    Like the title says. I am curios if you do how you are keeping your acid bath around 37 degrees?
    It depends on how big your tank is, your current density and how much area the work load is. Your cooling solution could range anywhere from dry ice chunks to a commercial chiller. I think people around here use fish tank chillers for small tanks and loads, but I don't have any personal experience with them.
    Process control doesn't give you good quality, it gives you consistent quality.
    Good quality comes from consistently doing the right things.
    Process control systems for Anodizers
    If a post helps you out LIKE the post
    I'm not an Amateur Metal Finisher. I've just been around the industry for a dozen years or so helping and consulting when and where I can.
