Dirtbike hubs
  • Dirtbike hubs
    So I’m a first timer with the anodizing and can’t seem to get it to work on my hubs on my 98 rm250 there stock hubs I practiced on an old sprocket and it turned out nice when I used the 720 calculator but I didnt follow the calculator with the hub because it said to leave it in for 26 hours and thought that couldn’t be right so I turned the amps up thinking it would speed things up. the hub came out a dark gray and wouldn’t take any dye if that helps . Thanks in advance !
    Are you using our LCD kit ?
    Jason Vanderbroek
    315 946 1213 x116
    www.caswellplating.com
