Hi there all,
Greetings from West Australia. Been playing around with anodising and recently discovered Caswell. I'm a keen Windsurfer and one aspect of windsurfing is about speed. To get speed you need flat water and to get that you either need a custom or specific landmass that allows the wind but no chop..or, you need weed. i.e. seaweed. Trouble is with seaweed it is highly abrasive and in some locations can destroy a $400+ carbon or fancy composite fin in hrs. Enter the aluminium windsurf fin. A fellow windsurfer has spent years making cast Al fins to some success. I anodised one of his fins in random fashion and it appeared to have much better wear resistance relative to its non anodised brothers. Anodising cast Al is of course problematic because of the porosity and other factors. Just putting it out there if anyone else has tried anodising cast Al. The cast is A356/7. Talking to Caswell Oz they reckon to polish as much as possible prior to anodise but experience seems to point to a 100 grit finish and LONG anodise....24hrs at 4.5 amps/sq ft density. This seems to fill defects. The ultimate aim is wear resistance but a secondary consideration is the dye. Not so much to look good but as indicator if the wear resistant layer still exists. I've taken a different approach to solve the problem and CNC the fin but would be very interesting if anyone in the community has had experience with cast Al anodising and if if extra long anodise time is beneficial or any other tips. Photos are of non dyed anodised fin and RIT dyed first attempt. Seems can only post 2 photos but have better result with turmeric dye.
