Checking part color cause variations in color
  • Checking part color cause variations in color
    Hi all. I think of all colors, I probably strugle with OD green more than any other. Now, the problem is that as I occassionally lift my part out of the dye bath to check how the color is taking, that seems to be causing slight variations on the parts surface. In the attached picture, at the top and bottom right hand corners of this knife handle (which I have now redone...again), there were darker areas. That aluminum was perfect and bead blasted, and well cleaned and degreased before it got the ano and dye bath. Any of you experienced this?
