I'm thinking of putting an Anodize line in, and I have some questions:
1. If I only run once a month, what do I do with the stuff in between? Would I throw it out and make a new batch, or put lids on the chemicals?
2. Do the chemicals create any amount of smell that would be offensive? (I have a shop in a building with other people, and don't want to offend them.)
3. If I were to buy one of the kits, what else would I need? Heaters, power supply, etc.
4. Are there any good resources that explain the process? I keep hearing about watching for PAR, etc, and I want to better understand that. I am an Electrical Engineer, and from what I am hearing, it seems like I could pretty easily build an automated power supply that would monitor the system, and shut down when it's "done". Without really understanding the whole process, I'm not sure if it's feasible or not. If it is, maybe I could make such a system and sell it to others through Caswell?
5. I'm trying to anodize cast aluminum boxes. Without first buffing them, can I get a uniform color? If the color would not be uniform, maybe it would look cool anyway?
6. Is there any real danger in this process? Chemical burns, explosions, etc?
7. OK, now a really ignorant question. With the chemicals involved, will a stainless steel heater work, or do you need titanium?
As I said before, I'm an engineer, and I need to know how everything works, so any info you guys can throw my way would be greatly appreciated.
Thanks,
Jon
Thanks,
Jon
