I've been using the caswell plates for the ground for abit with good success, but I've run into a problem where I needed bigger plates because of the size of my part. It left lighter area's in one spot and I would guess that's because I didn't have a big enough ground. Can I use Titanium for a ground, or is it just 6061 alum and/or lead. If I use aluminum I don't have to strip it each time do I?
Russ
www.professorwiz.com
Russ
