latly when i've been sealing annodized parts i have been having a problem with it leaving the part duel ( black dye the most). but it's shines right up it seems to be that excces dye is drying to the parts.
i rinse the parts after dyeing and use new sealer each time. ( keep forgetting to put the sealer away). could it be cause i'm using the steaming method over the submerging it the the sealer.
thanks in advance
thanks in advance
