I switched to the LCD method and am having trouble. I originally thought it was just a problem with the red dye, but the blue gets no where near as dark as it did before either. The parts anodized with the LCD method dont seem to have as thick of a layer either(they scratch easier). This all seems to have occured since I switched methods. The big things ive changed are the current limiting, done through a light dimmer switch in line with the power to my battery charger. The amperage is calculated by measuring the voltage across (4) .47ohm power resistors in parrell(.1175 ohms total). The ano bath mixture was changed to what was called out for in the LCD instructions, but in a larger container then before. I dont have fume balls in the tank any longer, no mist suppressant(or very little), and I havnt been using any air agitation like i had before. I dont notice any bubbles forming on the parts, so im guessing the air agitation shouldnt be a large factor now.....unless it creates a more uniform tank temperature that makes a difference. I also measured the PH of a couple things...and the red dye is way off from what Caswell states it should be, which is 5.5-6
*red dye- 8.3
*orange dye- 8.4 (Also, the orange dye was mixed with Caswell's red and yellow dyes, and only used once)
*yellow dye- 7.7
*green dye- 7.7
*distilled water- 6.2
*sealer- 5.5
I used a digital Ph meter purchased through Caswell, and calibrated after purchase. The sealer is rather old...about 4 months. I havnt been using it though....since the problems seems to be occuring before that I just dye and usually end up stripping and trying again before sealing. The ano layer does seem to scratch much easier then some parts I have that were done with the old method. Any ideas? The last part I did was 2.75"X1.5" and 3/8" thick. I calculated 11.4375 sq. in. At 4.5A/sq.ft. puts me at .343A. I got that by measuring .040V across the 4 .47ohm resistors in line with the anode. I let it anodize for 90 minutes. Part passed water break test before ano. Ano tank was 70-72 degrees. Dye was 145-150 degrees. Im not sure what to try out to fix my problem....is it the ano or the dye? If somebody could outline an easy way of monitoring for PAR, I would be very interested in trying to monitor PAR more closely and see if the 90 minutes is the problem. As always, any help is appreciated. Sorry if the post is garbled.....it's 4:30am and im not totally with it
*red dye- 8.3
*yellow dye- 7.7
*green dye- 7.7
*sealer- 5.5
