I've been looking though a bunch of the posts and haven't seen anybody discuss the pro's and con's of hooking more than one power supply to a larger part or parts. If you used say a large battery charger (with 2 amps), and a viariable power supply (5amps with a controller for the amperage and voltage). Wouldn't you be able to do larger parts in a pinch and still be able to detect the peak with the meter on the 2nd supply?
Thanks,
Russ
Thanks,
Russ
