I have an aluminum part that has a broken steel pin positioned about 1/16" of an inch below the surface of the part I want to anodize. It has proven impossible to drill out with my equipment. Can I just plug this hole with Caswell's masking agent or does the steel have to be completely removed? Keep in mind we are only talking about 1/4" max in total area of the broken steel pin. Is this that much to worry about?
If I was to attempt to anodize it with the pin exposed what could/would happen?
Thanks for the help.
