I was having problems getting parts to anodize using 12asf, so thinking it could be the fact that the acid was sitting for nearly a year with out being used I decided to try the LCD method. I mixed up 50ml sulphuric acid to 1000ml of distilled water(5% - the same as 1:3 battery acid). I started with a small quantity so I wouldn?t have a ton of waste acid if it didn?t work! I cut a piece of sheet aluminium 1 inch sq. giving a total surface area of 2 inch sq. So using LCD: (2/144)*4.5 = 0.06A and 2.5*(1/(2/144)) = 180 ohms so I needed 0.06Amps and my final voltage should be 10.8V?
I started anodizing and the voltages were as follows:
Time(min): Voltage:
start.......... 0.3
0.5(30sec). 5.5
1.............. 7.5
2.............. 8.0
5.............. 8.2
25............ 9.0
50............ 9.7
60(1 hour) 10
95............ 10.6
120(2 hrs) 11
140.......... 11.2
155.......... 11.4
180(3 hrs) 11.44
195.......... 11.71
215.......... 11.78
The meter on my power supply is anologue so the voltages were measured across the cathode and anode.
The part was drilled and threaded then the wire was forced through the threads, the aligator clip I used has sharp teeth and I forced them into the hanging wire.
I washed the part with soap then cleaned it with Pro-Clean(our equivalent of simple green) and it passed the water break test, then I put it in a 10% sodium hydroxide(lye) bath for 2 min, then in a 10% nitric acid with ammonium bi-flouride bath for 2 min to remove surface impurities, then into the anodizing bath. Seeing the voltages above I thought I had cracked the problem, but unfortunatly not! I took it off after the 215 minute mark thinking there must be something wrong. The red dye didn't take, I got a very very pale pink!(suggesting some anodized layer but not much) Is there something I am missing / any suggestions as to what I should try next? I originally thought the problem was the battery charger so I bought a 0-18V 0-10A lab supply, that didn't make a difference at 12asf so I changed to the LCD method thinking it was the acid, now I have proved that wrong. I figure it is the dye now! it had been sitting for almost a year(although I was also having problems anodizing when I first mixed it).
I also tried another piece doing everything the same just without using the nitric/ammonium bath, the voltage started at 0 but steadly climbed to 18.7V(max on my supply) then after a half hour it was down to 12V and very slowly climbing, its still in the bath now.
Sorry for the long post, I was trying to explain everything... did I miss anything?
Many Thanks.
Robert Harrison
Time(min): Voltage:
start.......... 0.3
0.5(30sec). 5.5
1.............. 7.5
2.............. 8.0
5.............. 8.2
25............ 9.0
50............ 9.7
60(1 hour) 10
95............ 10.6
120(2 hrs) 11
140.......... 11.2
155.......... 11.4
180(3 hrs) 11.44
195.......... 11.71
215.......... 11.78
Many Thanks.
Robert Harrison
