It is a Pyramid. Looks good to me. Just thought I would check with the pros on this.
Input: 110/60 Hz
Input Current:
230mA @ 0A Load
2.21A @ 5A Load
Output Current: 0-5A Adjustable
Output Power: 0-30V Adjustable
Fine & Coarse Voltage Adjustments for
Accurate Settings
Ripple: 50mV Peak to Peak Max @ 5A Load
Load Regulation: ?2%
Short Circuit Protection
Overload Protection with Reset Button
Dual Gauges (Current/Voltage)
Safety In-line Jack
Positive, Negative and Ground Output
Terminals
Complete with Test Leads and Manual
Suitable for Scientific & Technical Applications
Dimensions: 11.5"L x 9"W x 4.75"H
I also have a small question. When you do not know the part's size in ft^2, is it safe to feed it a small current and watch the voltage for par? Thanks.
Input: 110/60 Hz
Input Current:
230mA @ 0A Load
2.21A @ 5A Load
Accurate Settings
Safety In-line Jack
Terminals
