I am using Caswell's recommended 1:3 ratio 3 gallons battery acid to 9 gallons of water. I am using a 2/10/50 manual battery charger connected via the dimmer method.
I have a digital multimeter attached to the aluminium wire going to the part (anode) and also attached to my cathode. I am anodizing a part exactly 1 sq ft, so I am feeding it 4.5A, well actually just under 4.5.
The voltage starts off at around 12.5V, but seems to go down over time instead of up like everyone elses seems to. Is there a reason for this?
Thanks.
Thanks.
