Product: anodize
Base Metal: 6063-T6 AI
Amperage: 9
Voltage: 0
Temperature: 72
Duration: 90
Area: 275
Power Source: hp 6063b
Surface Prep: PARTS FIRST TUMBLES IN CERAMIC STONE. THEN DIPPED IN LYE ETCH 3 MIN. SPRAY RINSE, THEN REGULAR WATER SPRAY THEN DISTILLED SPRAY, THEN IN DESMUTT FOR 3 MIN, SAME RINSING AS ABOVE.
Problem: THEN INTO ACID. AMPS PRESET TO 9.3 LETTING VOLTS DO THEMSELVES. ACID AERATED WITH YOUR AERATOR. PARTS ON AL RACK CLAMPED TO AL BAR ACROSS PAIL WITH + TO AL BAR. GROUND USING THE TO LEAD PLATES YOU SUPPLIED ONE ON EACH SIDE OF PAIL. VOLTAGE DID NOT FOLLOW THE CURVE FOR PAR. TOOK OUT, SPRAY RINSED AND DIPPED IN DISTILLED WATER WITH BAKING SODA. SPRAY RINSED AND DIPPED IN DISTILLED WATER. PUT IN CASWELL DIE AT 130 F FOR 5 MIN, TOOK OUT SEEMED DIRTY. (IF I DON'T TAKE OUT AFTER 5 MIN AND SPRAY, PARTS JUST STAY LIGHT BLUE) SPRAY RINSED AND PUT BACK IN FOR 30 MIN. CAME OUT FAIRLY BLACK BUT COVERED WITH HEAVY BLACK SMUT. I AM LOOKING FOR MAT BLACK FINISH. NOT QUITE MAT AND COVERING NOT PERFECT. WHAT AM I DOING WRONG.
Solution:
That seems a large amount of material in the tank, is it one piece or lots of little ones? Sounds like you aren't growing the film correctly And THAT sounds like bad connections, especially as it didn't follow the PAR curve etc. I'd suggest you also post this on our anodizing forum.
am going to change the leads from my power supply to the work, will post any changes that makes.
Thanks in advance guys.
Amperage: 9
Voltage: 0
Temperature: 72
Duration: 90
Area: 275
Solution:
