I have came to the milestone in anodizing where tank temp is a real
issue. Yesterday I tried doing some engine mounts for my buddy's
race car. Although I felt that they were to big for my 5 gal setup I
did them anyway. Tank temp and current started rising rapidly but I let
it run just to see what would happen. After 1 hr 15 minutes the tank
temp hit 100 deg F. The fumes were terrible. That's when I chickened
out and pulled the plug. The plan was to do them clear so I don't
know how well they would have taken dye. They do pass the ohm meter
test and look pretty good considering the temp.
I am considering buying a 5 cuft chest freezer to use for a tank.
Now since a freezer would be to cold for type II, I have an external
temp controller with a thermocouple I could drop into the bath. The
controller plugs to 115v and has a 115v outlet where I can plug the
freezer and cut off power at the cord at whatever set point I desire
(-300 to 3000). Its a little over kill but I already have it lying
around. The 5 cuft freezer would be about 37 gal so I would probably
fill it with about 25 gal of electrolyte....
Now this is where I need everyone's opinion. I don't suppose
freezers are designed to be filled with liquid so I'm wondering if
the walls may fail and leave me with 25 gal sulfuric in my basement
floor? The irregular shape of the inside of a small freezer makes it
difficult to put another tank inside it without losing much of the
25 gal volume. I would also hate to step up to a bigger freezer
because of cost and lack of space for a large one. I like the idea
of just using the 5 cuft freezer for the tank but I am a little
apprehensive about it.
What do you all think?
