Hello all!
Newbie to the board here . I work for a prototyping firm that makes models of consumer electronics. We've decided to break into anodizing with a caswell system. We purchased the setup over a year ago (pre lcd) I've recieved the new voltage parameters but my power setup is far from optimum, currently a 6A battery charger. The first power supply we got was a 60 amp voltage adjustable ,which lasted a month before I crossed wires and killed it. DOH! Next we got a 10A non-adjustable reg. power supply which just fried inexplicably. Now this unit provided decent results although I don't have a rheostat to control it. With this unit I was able to do a run of samples for my client in various shades of orange to reddish. Well he chose an orangish tone which I then tried applying to the actual parts. Now the parts come out a brite gold even when dipped into an obviously orange dye formula at 140F. My Tank is at room temperature. De-smut at 100F. what is preventing absorption of the red? I've tried different anodizing times with mixed results. I understand that control of the current is critical but what precisely do you change and why? thanks everybody
