Sealing
  • NeoMoses
    Yes, the old pot on a hot plate should work just fine. I would recommend the regular sealer since it is compatible with all dyes that caswell sells.
  • RPE
    started a topic Sealing
    Sealing
    Hey guys,
    I have a kit that was purchased about 3 years ago and have the metal coated pot that was used for steam sealing.
    Can this pot be used on a hot plate to do the sealing or do I have to use a plastic tank and buy a ceramic heater to do the sealing?
    Is steam sealing a thing of the past or will it still work following the new procedures?
    Which is better the LT sealer or the regular sealer?
    Randy
