Hi all!
Would it be ok to use a cheap stainless-steel pot for the Nickel Acetate sealing stage, as I intend to use an external heat source? I've read that only 316 should be used, but does anyone have an experience of using other types, as the cheap pot is almost certainly not 316?
Thanks for any help you guys can give!
-Tone.
-Tone.
