Has anyone tried titanium and aluminum hanging wires in the same batch of parts? If so will the parts look different from each other when dyed?
Titanium and Aluminum in same batch
If you anodized two identical parts together, except that one was suspended from aluminum, and the other titanium, the titanium one would receive less current. Why? because aluminum is a better conductor than titanium. Mixing titanium and aluminum adds another variable and provides no benefit.
I can provide a simple answer to your case.
If you are suspending the work from wires; what's important here is that the surface area of the wires is much less than the surface area of the work, there won't be much of a difference between aluminum wire and titanium wire. The titanium wire will drop a bit more voltage than aluminum wire, but a CC power supply will compensate for this automatically. Nothing to worry about. If you had two pieces of work in the tank together; one with Al wire, and the other with Ti wire, the CC power supply won't know which to believe, so it will strike a compromise.
This situation gets much different with racking, since the surface area of the rack is often larger than the total surface area of the work, so the rack is setting the current density, not the work.
Originally posted by FibergeekIf you are suspending the work from wires; what's important here is that the surface area of the wires is much less than the surface area of the work,...
Use a smaller gauge wire. As an example; 14 AWG is 0.062" dia., assuming a piece 6" long in the electrolyte:
Surface Area (SA) of a cylinder is Pi x D x L (ignoring the area of the end of the wire)
SA = 3.14 x .062 x 6 = 1.17 sq. in. That's about .008 sq.ft. your part is that small?
If you used 18 AWG (.038" dia.) The SA would reduce to 0.71 sq.in. (.005 sq.ft.).
The violet colored part in the pic above had about .0002 sq.ft. If I used .062" wire and only had 1.5" length in the electrolyte then the wire and part would be close to equal. I have been using alum wire and a CV setup to do these so far but would really like to make some reusable Ti fixtures to hold them. The small alum wire breaks after the first use.
Hmm, I don't know what the deal is, try this link instead:
http://www.geocities.com/jtsuttle/x_tra_small.jpg
That link says "page unavailable". Don't worry about it.
3.14 x .062 x 1.5 = .093 sq.in. , let's call it 1 sq.in. (.007sq.ft.)
Find some spring temper Ti wire, Servisure sells it among others. You'll want a small gauge, smaller than 18 AWG, let's guess and say 20 or 22 AWG. The stuff should be tough to put in the bends you need to form the appropriate spring, you'll have to experiment to determine what a suitable spring for this should look like. It's clear you want the smallest spring that you can get away with, you'll do this anyway when you see the price of titanium wire.
Since I haven't started my titanium experiments yet, you'll be using "Kentucky Windage" anodizing (you guess the current to apply) start with say 1/3 more current then you would use if the wire wasn't there. See what happens.
