having recently started anodizing at home, with the normal startup woes that seem to beset any new project, i am left with one slight problem to solve. I have the acid tank setup with 1 bottle of fume control chemical added but without the foam blanket present unless the surface is agitated, ie when i use a device for checking the SG. Any suggestions as to causes and or cures would be welcome
Regards, lawrence
Regards, lawrence
