I have a question about the rectifier issue. I know that a CC rectifier is needed for anodizing, but whats the possibilitys with a none CC rectifier?
The problem is that i have 2 rectifiers already and none of them are CC.
One of them has 2 knobs (for voltage, and ampere) still its not CC.
If I would do a LCD-anodizing and act as CC myself, that is adjusting the Ampere by hand during the process, would that be possible. I could maybe connect a Ampere-meter to the system and check that the ampere is in the right range by adjusting it?
The thing is that I only would like to anodize one small part in a system a build pretty rarely, so i could spend some time adjusting, if that now is possible rather than spending money on another rectifier
Thanks in advance
Thanks in advance
