Hello all,
I am having some problems with pitting and dissolution.
I have:
-25 gal tank (15"x12"x30") with air agitation.
-sulfuric concentration 4.8% by volume.
-cathodes are two lead 8"x8" plates on the ends of the tank.
-temp steady at 64°F
-power is sorensen DCS40-25 (40VDC @ 25A)
The parts are hung from a rack using caswell's titanium hanging wire
It seems as though the connections are holding well.
The parts are always more than 4" away from a cathode. They can be as far as 14" away if they are in the center of the tank.
For cleaning I use several stages:
1, hot water and dish detergent
2, aluminum rim cleaner in ultrasonic
rinse
3, SP degreaser
rinse
4, sodium hydroxide 15-30 sec
rinse
5, caswells desmut
rinse
7, Ultrasonic RO water.
rinse
Anodizing tank approx 90 min based on 4.5 amp density.
Parts total area is 100 in² and the current has been set at 3.1A
At this point, the only thing I can think of is agitation problems.
The air bars seem to move the fluid around plenty, but perhaps it is not enough?
Thanks!
I have:
rinse
3, SP degreaser
rinse
rinse
5, caswells desmut
rinse
rinse
Thanks!
