I know I was told by the forum moderators to leave the cast aluminum on the shelf for now but I have anodized quite a few pieces of the 6xxx bar stock and I even went out and purchased some aluminum stock at the hardware store and anodized them with the same good results. My setup is the standard Caswell deluxe kit using the 20 amp CC power supply sold by Caswell.
The piece of cast aluminum was a large boat cleat with a total SF of 45 square inches. I decided to anodize this piece using 6 amps per square foot. My calculations arrived at 416mA per square inch x 45 square inches and I then set my constant current power supply for 1.9 amps. Please correct me if I have made any mistakes, I’m new to this procedure and seeking any help I can get.
I decided to make voltage readings at ten minute intervals and they where as follows:
Voltage
Start 8.6V
10 min. 9.9
20 min. 10.3
30 min. 10.5
40 min. 10.8
50 min. 10.9
60 min. 11.0
80 min. 11.0
90 min. 11.0V
I removed the cleat after 90 minutes rinsed it in sodium bicarbonate solution and then distilled water. I plan on just anodizing the cleats and polishing them but I wanted to check if this cleat would hold dye and to my surprise it did. The cleat is deep black in color with no signs yet of discoloration.
On a normal run I watch and record the voltage, it usually drops through out the run. I could see on this run that the voltage immediately started climbing, was this my first experience with dissolution? Could you explain what happen during this run and how I could improve my results? Thanks again for your help.
Voltage
Start 8.6V
10 min. 9.9
20 min. 10.3
30 min. 10.5
40 min. 10.8
50 min. 10.9
60 min. 11.0
80 min. 11.0
90 min. 11.0V
