Hiya guys, hope you can help answer a few questions, I am new to anodizing!.
I am from the UK and will be gathering my own kit, very basic at first, but then develop it!.
I want to idelly start a sideline in anodizing car bits n bobs (throttle bodies, alternator casings etc), maybe even bigger Cam Covers etc oneday.....
I intend to use a storage box (plastic) as my anodize tank, with two aluminium sheets as cathodes at each end (8x8 i expect). Battery acid 1/4 and 3/4 dionised water as my electroyte.
A Car battery charger will be used as my power supply.....and for now I will be using fabric dye to dye components, although if i get "good" results, ill look at upgrading to a propper setup (before doing things for other people), with Caswell dyes.
I have 3 main questions that would help me get started!
1) One of my peices i plan to anodize has 3 mild steel fixings in it, can i dip these anyway, i know they wont get anodized, but they cant be removed
. OR will they wreck the peice?
2) If you use Aluminium Cathodes, dont they anodize too and have to be replaced (due to loss in conductance?).
3) Current Density. I dont really understand how to work out timings, I have seen the 720amp minutes thing, I assume I have to start the peice going, read the current draw, and then work out the time required based on surface area? As i wont be able to control the current much (battery charger), so I assume i must read the current first and then calcultae timings?
Many thanks in advance
