Hiya folks, hopefully you can shed some light on my problems.
I have the following setup;
2ltrs Battery Acid to 5ltrs Deionised water.
Aluminium Wire (v thin, 1mm diamter)
2018 aluminium test peices (1inx4in)
0-16v Rectifier (40A continuous max)
8x8 in aluminium cathode
Okay. Here what i do from the start.
The peices of aluminium to be anodised are firstly cleaned with detergent and then rinsed, and dipped for 5mins in Caustic Soloution (Sodium Hydroxide).
In the Caustic soloution, it bubbles after a minute or so and fizzes away nicely. When i remove the ally from this, it gos from being bright finish, to an almost white looking one.
My aim for this caustic dip is to have it clean up any oxide layer that may be on the aluminium beforehand.
I then place the aluminium test peice in the anodis bath.......volatge is set to 15V and the current on the meter is 0.4A. (Bath is approx 10DegC)
I tap in the surface area and amp reading into the calultors and it says 120mins.
After a bit the cathode has lots of bubbles all over it (small ones), Ammeter is still reading 0.4A. The cathode also appears to have gone a bleached whiteish colour where its been in the acid.
After 2hrs, its still bubbling away slowly on the cathode, the ammeter still reads 0.4A, and i remve the test peice of ally....its a whiteish kind of colour, i rinse it in water quickly (dip), and then submerge in the dye bath (about 20-30degC) for 15mins.
I remove the peice from the dye and it looks just the same as it did before it went into the anodise bath/the ye bath...nothings changed, not even the wire has taken dye
Im in dispare! Can anyone give me any pointers or see any errors?
Many thanks!
Many thanks!
