I need to raise the ph level in my acid tank. I should add more acid right?
Ph level
No. Higher pH is less acidic, lower pH is more acidic.
Since I think you are talking about the electrolyte in an anodizing tank, the acceptable acid content range is much wider than is normal for a lead/acid battery. pH measurements of anodizing electrolyte is a waste of time.
It seems I can't get my amps up.
Increased acid content and higher electrolyte temperature will both lower the electrolyte resistance, thus requiring less voltage for a given current. But in anodizing, both increase the dissolution rate, not a good way to fix the problem.
Check your connections.
