Well after a year of life getting in the way I finally got my Caswell LCD system going. I have done three runs and had mixed results. One thing I dont quite understand is I am sure that my first attempt was a falure but the part took dye. The reason Im sure it is a failure is that when I do a continuity check on it I get 000.0, actually my second run showed the same results...took dye but still conductive. My last run however was a little different, it wont read anything at all when I check continuity, although it trys if I rub very hard with the probes. The part was not like this when I took out of the ano bath. It would give me the 000.0, but after the sealer it seemed to be what I wanted. The color on all the parts is not what I want yet but figure that is a result of to thin a layer, but I am confused about the parts taking dye. I thought that a piece would NOT take dye unless the process worked?
Well for kicks Im adding a pic to show my "first" results. I used Caswels Electric blue, and the other is gold. The small blue piece was first run. the gold pieces were second run and I did them both at once. Then the brake lever was my third try and it seems to have worked but not very good. I am curious how dark the electric blue should look.
