okay - Yet again I'm having more problems.
After running a couple scrap pcs though without a hitch (and a surprisingly good finish despite the lack of prep) I thought I would start for real. This involes of course lots of prep. I'll run what I did.
1. deburr
2. bead blast with glass bead
3. deoxidise
4. desmut
5. anodise
6. dye
7. seal
okay - all within normal recommendations with a rinse with demineralised water in between. What I ended up with was a patchy dye finish.
A couple more tries and I noticed that the unprepped surface came out great but the bead blasted surface didn't.
Could the bead blasting be forcing the oxidised layer deeper into the metal?
I thought that could be the case so I'm just now trying to give it a very hard sand. A very long soak in lye and a rinse, dry, bead blast, and so on.
I'm still getting some mixed results and have been getting slightly more aggresive with things but I was just curious to see if anyone has had this before?
The other thing I noticed was that when the parts are anodising that I sometimes get darker grey areas while in the sulphuric acid.
Could there be a contaminate somewhere? Could the glass bead be embedding itself in the metal?
Everything is clean and fresh. All solutions are new and made with demineralised water. The glass bead is fresh. I can't think of anything else.
I need a good solid black finish! So come on fibregeek - HELP ME!
On a side note I've figured out how to rack screws if anyone is interested. At least with a 90/95% success rate.
1. deburr
3. deoxidise
4. desmut
5. anodise
6. dye
7. seal
