Anyone know of a good marind grade sealer. I am anodizing my fishing reels and need a good marine grade sealer.
Marine Grade Sealer
Teflon molecules are much too large to get into anodize pores, the teflon sits on the surface. This by definition does not qualify as sealing anodized layers (it's not in the pores).
That said, if you want to put a teflon coating over the anodize layer, go ahead. If the anodize is dyed you will have to seal it properly before the teflon, the dye will leach out if you don't.
