anyone with annodizing experience please take the time to read and suggest a solution to my problem
ok i tried to anno some small parts ( 2 paintball marker feednecks) today and it did't go very well.
i tried mulitple configurations of the power supply, i tried 2 different chargers , and then hooked 2 batterys in series to get 24v and the most current i could pull through it was about .2 of an amp
i dont this can be normal from reading some guides as they suggest regulating the current with light bulbs and im not getting enough to even light 1
suspected problems:
1,
because i live in the uk (nanny state) anything vaguly harmful is pretty hard to get hold of, car garages etc dont keep battery acid because the batterys are filled before they are deliverd to them and the only way i can find to get it is through wholesalers in bulk..
so currently my only source of battery acid is from discarded truck batterys
the first time i hooked my setup up i got it the wrong way round and the ammetter maxxed out (6+ amps, which suggests to me that the acid is fine) but soon as i switched it round the right way round i get a .1
in summary im not sure what to think about my acid supply
2. i wrapped my parts in very small gauge aluminium wire (can used for mig welding i think) i did't manage to get it wrapped particually tight as it kept snapping.
so i think i could have an connection issue but i would have though i would have started out with a decent flow and then it would deminish
Results of my day of annodizing, i managed to dye one of the feednecks but it did not dye black as hoped (i used caswell black dye) it was dyed a fairly odd greenish color which changed purple in the light kind of like flip paint (the finish was pretty raw on that feedneck still had marks from the lathe left on it)
it was also very easy to scratch which suggests a thin layer of annodizing
other details
i washed parts down with white spirit, similar to turpentine
surface area was in the region of 7 square inchs
i used caswell annodize and chrome stripper first
i used caswell dyes
i annodized for approximatly 30 minutes (the part was still bubbling when i took it out)
thank you for reading any help appreciated
suspected problems:
1,
other details
i used caswell dyes
