Several general questions re: the LCD kit
application background ---we design/ build custom optical sensors (cameras) so we are looking for flat black.
1. Is there a need to heat the dye...I find room temp. works well?
2. The value of the supplied sealer (nickel acetate) vs. plain boiling water ( I hate the chemicals!)
3. Will higher current density ( 6 A vs. 4.5 / sq. ft.) reduce anodizing cycle time?
4. need to remove cathodes during perpoids of non-use ( 2 weeks)
Thanks one & all.
Thanks one & all.
