commercial readily available desmut
  • destroyer125
    let us know I wanna know if this works :P
  • sswee
    Phosphoric acid is commonly found in a rust treatment chemical farmers have been using for years to treat their cattle trailers.
  • SniperSlayer
    one way to find out where can you get ahold of this acid i've never heard of it being used before
  • captmorgan
    redback
    So, you won't tell us the reasons for using phosphoric acid. Are you keeping valuable secrets from us? Must we invoke the Freedom of Information Act to learn this important information?
    I have been using a lye solution as a stripper. Although it works, it can't help but dull the finish or if used too long, pit the surface. Does phosphoric acid attack the aluminum? I could use a cheap alternative to lye.
  • sswee
    A quart of Caswell DeOx/DeSmut makes 2 gallons.
  • destroyer125
    you can buy de-smut in I think 10 gallon amounts from caswell
  • redback
    started a topic commercial readily available desmut
    I am removing anodise with phosphoric acid (for reasons I wont go into I cannot use lye, caustic soda)
    the anodize removal works fine but it leaves the surface of the aluminium with a smut or greyish colour
    is there a readily available agent I can use as a desmut
