I made another run today, 3 parts at .5 square foot, ps set at 6 amps CC mode, ran up to 19 volts, the just hovered around 18.3 for the entire time, I did get very little white powder after I was finished, but I think I could run for 30 more minutes set up like this get a thicker anodize growth, for now I'm happy with this, the color didn't take as well as the half mill test before, but you can tell by using sand paper that this is much harder.
This setup gave me 12 amps per square foot, I cooled the water with ice before I started, ~60*, still have not gotten my pump so agitation was by hand. My mask failed again, I used spar finish, It may be failing because I'm bead blasting before i anodize as a clean step.
The 170-325 grit glass beads gives a super fine matte finish, wow this is a great finish to anodize over. I'm going to try rubber cement on the mask next, I would buy the stuff from caswell it's cheap, but the darn shipping is as much as the mask LOL. Can you bead blast over the mask, if not how are you cleaning ?
Clint
Clint
