If anyone ever comes up with a sure fire way to anodize cast aluminum I would love to know. Here are some triggers off a Ruger 10/22, they anodize a dark gray color, will not take dye, and worthless unless you like the gray color. You can see where I tried to dye two of them and they come out a blue haze, but gray is dominate. Any ideas ? I done the etch, and de smut from Caswell, then I trie done after I anodized it in the de smut, polished, bead blasted, different times in the tank, different amps per square inch etc etc I can't find a way anodize this cast and get the results I want. I have anodized many other types of aluminum, and even some cast with zero problems and perfect dye.
Clint (not sure if I can post phots or not)
