Thickness of anodising
  • Thickness of anodising
    hi folks, i have some microphone bodies with a extreemly fine thread i need anodised, and i was wondering if the process would clog the threads?
    what are your thoughts?
    the thread size is approx 65tpi
    thanks in advance
    matt
    Re: Thickness of anodising
    Why risk it when you can use plugs, Mask-it or tapes to shield the threads?
      The anodize will not clog the threads. It may tighten them up a little. Most threads cut in production are at least a class II. Sometimes a class III. If you feel some slack in the threads now, you should be ok. SS
        it is an extreemly tight and fine thread. we will see, i will ask the anodising guys advice, he will have a better idea of his processes.
        thankyou
        matt
