Re: Is this OK - PYRAMID PS36KX 32 AMP PS
Should look more like this:
http://cgi.ebay.com/TEKPOWER-LINEAR-...QQcmdZViewItem
Thanks sswee,
I will keep looking....
-Ken
Anodizing whether LCD or not gives better results when using CC. The PS your looking at is not CC capable and not the best choice. You can get a PS that is CC/CV for the same or less money as that one and be happy in the end.
Would the Pyramid PS36KX 32 Amp power supply be a good choice for non-LCD anodizing?
Here's the link:
http://cgi.ebay.com/PYRAMID-PS36KX-3...QQcmdZViewItem
It doesn't have adjustable current, only adjustable voltage. I would assume it's OK but I thought I'd ask the experts.
- Perfect for Home, Shop and Hobbyist
- Built-in Cooling Fan
- Input: 115V AC, 60Hz, 600 Watts
- Output: 12~15V DC(Adjustable)
- 32 AMP Constant/35 AMP Surge
- Screw Terminal Connectors
- Crowbar Over Voltage Protection
- Short Circuit & Thermal Protection
- Fuse Protected
- LED Protection Indicators
- 3 Prong Grounded AC Plug
- Heavy Duty Cabinet & Heatsink with Non-Skid Rubber Feet
- Dimensions: 14''L x 9.17''W x 4.92''H
Thanks for your help,
KenTags: None
