I'm trying to anodize a 6.5" diameter by 9" long tube (inside & out), comes up to 366 in? SA. Ano tank is plastic tub with 6 gallons mixed at 1:3. I have 4 GP plates, so if only the facing side counts I'm running a bit 'lean'.
I did one of these before and it anodized and dyed beautifully. My CC power supply maxes at 10 amps, just a little lacking for 4.5 CD, so I calculated it out to anodize at 3.9: 9.9 amps for 129 minutes (.7 mil thickness).
I haven't anodized anything in about a month. The tub was covered but not sealed, and doesn't look like a significant amount of water evaporated. The last tube had parts with threaded holes epoxied to it, so I attached anodes there (I measured resistance between the parts and the tube first to make sure the epoxy wasn't isolating them). This one is a bare tube and doesn't have any holes to tie into, so I've got three titanium wires pressed up against it. If I measure resistance between any two of the three it's less than .5 ohm so I think the connections are good.
If I place the tube in the tank and measure resistance between a plate and any of the titanium wires, I get 0.0 ohms. If I clip a wire to a flat bar and stick it in the tank, it measures 150 kohms. If I let the bar touch the tube, it goes to zero ohms (this is without the tube connected to anything and the power supply is completely out of the loop). I checked about 8 times and the tube isn't touching any of the plates. The tube definitely dominates the tank, but I verified that I have at least 3 inches between the sides, ends, and plates. I watched the ohmeter while raising the tube out of the tank and it stayed at zero until the tube cleared completely.
I can't get the power supply to kick out any current and I suspect that it's because it's seeing that zero ohms and its short circuit protection is keeping anything from happening.
Any ideas? Like I said, I did one of these before and didn't have this problem so I'm at a loss as to what's happening this time. The last parts I did came out fine and the tub's been covered since then, so I don't think it's a contamination issue. I've been very careful about only using RO water for all phases. The only other difference between the two tubes is that this one was tumbled and the other one was not, but I've washed this one quite thoroughly by now - and it does pass the water break test.
