Black Dye
  • Black Dye
    Any experience in running black dye cold (ambient) as opposed to suggested 140 deg.
    Occasionally, I get a dark blue, my thoughts are that the structure is closing before full dye penetration occurs.
    Re: Black Dye
    The dye works best at 140 degrees. Some have said they use it at room temp but the problem of a dark blue color usually is old dye or too thin of a anodic coating. Since it is an occasional problem and seeing your other post I would think that too thin a coating would be the most likely cause. Do you use the 720 rule? What CD do you use? What PS are you using?
    SS
      Re: Black Dye
      I have found that you have to anodize to a full 1mil coating thickness for a deep black color. Use the 720 calculator.
      Although the black dyes very easily, I have not had good results dyeing at room temperature.
      I do things.
