my black dyes have been coming out pretty pale recently and i think it may be the dye. I've checked the Ph and ajusted it to 5.5 -6.0, but the part still comes out pale. Is there any way to check to see how much dye is left in the tank.
Dye problems
Re: Dye problems
I use quite a few different colors and haven't used any particular color enough to deplete the dye. Maybe one of the other guys can help on that question. If your running 20% acid, the pale color could be caused from too thin a coating and /or pore size too large to hold enough dye for a dark black. SSLast edited by sswee; 12-22-2005, 12:05 PM.
