Greetings All,
I am brand new to your anodizing experience, but you have me 100% hooked!
And thus--- the reason for that funky thread title:
I have built a 3gal system (in a little over 24 hours) once I received
the Caswell's black die and sealer products and my first 6061 and 2024 motorcycle parts off of my CNC lathe were done with the black. It took only
2 practice parts (I have polished AL many times before-- so I knew the proper prep spec) and the rest were very nice indeed.
So I read Ron Newman's gibberish and followed it (only because I bought it!)
and now I know there is better.
Years of my own development to create an excellent salt brine for my smoked chickens gave me the intuition that this Battery mixture could be better developed. Chewing gum --- you now how we like to chew gum and how
it should stay soft because our teeth are smakin' down hard on it, yet after only a little bit the darn stuff gets hard . . . . . . ok --- well that taught me the reason for our Mr. Aluminum's dissolution, creation of a permeable skin layer (known in the Caswell world as PAR). And finally I have made intelligent
programming decisions for the usefullness of an inverse video block to guide
data keypunch applications for improved accuracy and ergonomics--- so
our Electical Rubic wasn't so confusing after all. PAR is the inverse logic
of my battery charger's power addendum!
Ok-- seriously, If U have stayed this long thanks!
I would like to develop an excellent results oriented 3 gl anodizing system.
I will buy the Caswell CV, CC PS but which one is appropriate for my system size? That 20amp is very nice but . . . . The lowest priced one isn't tunable
So--- is the 5amp appropriate?
I have ordered 2 of 8"x8" GP Plates (lead sheets) for my cathodes. BTW-- anybody wants to see HOW big a set of cathodes can be let me know.
I need air! I have purchased an aquarium air pump for this reason. But
if I had intelligent opinions available--- what would anyone like to see designed?
I have my dye tank nicely done now. The heat is registered fairly well from
130 to 140. What about agitation in a dye tank?
I am waiting on a heater core from Caswell for my sealant tank.
My rack is a 5/8" round Titanium bar and my wire hangers are 10 gage solid AL. I use my own "J" bends and use 1 set (series of 2) -- with a "J" or "U"
bend from opposite openings in my parts. Secured tight to the Ti bar.
OK--- have I missed anything?
I hope I have entertained a little and hopefully made a decent presentation to
encourage your contribution.
This is an excellent forum with some very knowledgeable contributors (I read
a lot!--- and looked at a ton of pics!).
thanks for your consideration and help,
scott
scott
